In the Netherlands most grid connections are TN-C-S. Basically when installing an ESS, no real need to make things more complex and simply use the existing grounding.
I’m contemplating on adding a generator for emergency use only. Not by using a 4th Multi but by reconfiguring the existing ve-bus setup in such an emergency situation (set grid code to none, un-tick switch as group for the 3 phase setup, etc). The config switch would basically result in an off-grid/island mode only installation where grid N-L1-L2-L3 are switched to generator N-L1 (N - PE bound in transfer switch, not in generator as per recommendation).
So far, so good. But if the actual grid connection is somehow damaged I will end up with a bounded but not grounded generator connection. Not so good?
I still have a decent ground rod from when we first build the house. It was disconnected from the wiring closet in the house when the setup was released for use a long time ago. I have read that it is within standards to restore that connection by merging the ground rod connection with the TN-C-S ground for added safety.
DESS/ESS/Victron and generators aside. Anyone care to comment if my interpretation is correct ? Safety will increase by adding a ground rod to the TN-C-S connection from the provider at the entry point / central grounding terminals ?
