I am getting confused by the different temperature readings. Since 2 months I have 2 Victron LifePO4 NG 25.6 V 300 Ah batteries on my yacht. I keep a close eye on cell voltage, balance and the temperature. Yesterday I had measurement of 46 degrees showing on the dashboard of VRM and on the Remote Console. That scared me. When I checked the the detailed temperature of the cells, it said it was only 14 degrees. So now I am confused. See screenshots. Where is the measurement of 46 degrees coming from? Do I need to be afraid something is going wrong?
Good afternoon,
Ask your supplier, you might be looking to make a RMA to substitute.
Don’t worry if your battery is 14 degrees and shows 46, as there must be something wrong in the BMS, it will not catch fire…
Regards, Jeroen.
Is there a temperature sensor physically connected to the Quattro?
You could check the settings for it, and it might show the 46C.
Did you used to have lead acid batteries with a remote temperature sensor. I had this set up and changed to NG batteries and it kept the old temperature sensor as the battery sensor. When the new BMS was put into the system it did not automatically reset the battery temperature sensor. This is a Venus OS issue. I sorted out a work about to get Venus OS pointing to the BMS suppliedbattery temperature. I will search this and post a link.
Thxs pwfarnell. I did indeed have lead acid before with a remote temperature sensor. This would explain the situation, but why 46 degrees? Is that an actual measurement or a phantom and random number?
Faulty temperature sensor. Or a hot terminal because of a loose connection?
Only two reasons I can think of.
Either way the old temperature sensor can be removed
@jurjenhoekstra See this post, sorry it took so long to get it.
That temperature reading is almost definitely from a sensor atttached to your Quattro. I have a similar setup. So good thing is it is not your batteries.BTW I don’t think that reading will result in any derating of the system, however I would be still a bit concerned about it and would investigate further and why (if correect) you are getting a temperature of 46C somewhere.
