Tailscale in 3.5x
Hi all,
I read, tailscale is now integrated?
How can I activate it?
Using a Cerbo GX Mk2 with 3.53
First … install the Setup Helper on your GX …
Start your console in the ‘V1’ version … i.e. the old UI … then the Package Manager at the bottom … here you will see the ‘Extensions’ and can then select them …
Not talking about TailscaleGX, it should be already implemented in the actual Firmware
I do see tailscale menus under Services however it just stays in Starting… This in firmware v3.53.
TailscaleGX should be testing for tailscale at /opt/victronenergy/tailscale and if so block the install in order to prevent conflicts. This directory does not exist so this may not yet be fully implemented.
I find nothing in the Venus OS change log about tailscale.
Native Tailscale was only added to GUIv2, but not yet in the firmware.
