I have two controllers:
EPEVER MPPT and MPPT RS 450/100 and SmartShunt.
For synchronous charging of the battery and synchronous passage of charging stages (absorption, float) it is necessary to control these devices.
With EPEVER everything is simple, I control it via Modbus.
It is necessary to transfer to MPPT RS:
- the voltage and current values measured by the SmartShunt.
- at the right moment to give a command to MPPT RS so that the charge current is maintained at zero.
Now I am geting statistics from MPPT RS via the VE.Can.
I cannot find the necessary vreg command in order to implement points 1) and 2).
Maybe someone has solved such a problem.
Thanks!
