Spurious low battery warnings
Hi for quite some time now I regularly get low battery ALERTS notifications from VRM while my battery is completely fine with pleny of chenergie. The CLEAR message always follows a few seconds after that.
The system is setup with a min charge setting of 11%.
See below email I received while the battery is at around 51%.
Subject: ALERT - ‘Hweg’: ‘Low battery’ on ‘VE.Bus System [276]’
Date: Wed, 4 Nov 2026 18:48:49 +0100 (CET)
To: marcel@emol.nl
VE.Bus System [276], Low battery: Alarm
This email is generated by Automatic Alarm Monitoring on the VRM Portal. More information:
VRM Portal alarms and monitoring [Victron Energy]
Subject: CLEAR - ‘Hweg’: ‘Low battery’ cleared on ‘VE.Bus System [276]’
Date: Wed, 4 Nov 2026 18:49:08 +0100 (CET)
To: marcel@emol.nl
VE.Bus System [276], Low battery changed from ‘Alarm’ to ‘Warning’
Am I missing something or is this a bug?
Happy to receive suggestions for further test…
-Marcel
This can happen if the connection to the battery BMS is unstable.
It can also happen when the GX device is overloaded and cannot allow communication between the BMS and the MultiPlus via DVCC. That’s probably what’s happening here, if the clear is immediately afterwards.
I have seen this on installations with a Color Control, which has limited processing power
Is this a 15S or a 16S battery
Do you use ESS and how are the cut-off values
Example 16S
So first of all, I was mislead by the alarm in thinking it was about SOC values, while it indstead is about battery voltage. Maybe the alarmmessages could be a bit more informative.
This is a 16S system (3x16 EVE MB31)
20 minutes ago I changed the cut off voltages (lowering all off then by 0.5V). Currently thaey are set to:
Let’s see if that helps a bit
Below the voltage m,easurments during the day. battery SOC was above 50% the whole day.
I don’t understand why there are such sudden voltage drops…
You are running them at the bottom end of their cell range with close to 100A load. Lifpo4 are known to have issues there. And more so if the battery bank is ageing or weak.
Massive drop under load could be high resistance in the battery, or DC to the inverter. I see a 0.3v drop between the battery and inverter). So if that is a DIY battery check it is still ok in construction. Or just give it a good charge to full.
Then you can have soc drift as well to add to the confusion.
So 47v at 50% does seem a bit low to be honest as I scanned first I thought you had 15s batteries untill I read deeper.
Hi LX, thanks for your comments.
I also thought the SOC values me be a bit at drift so I started running a full charge last night.
So far it charged 40kWh, which is around 80% of the capacity. So SOC drift.
So my lesson is to fully charge more often :wink:
Indeed, it’s a shame that the alarm email doesn’t include any values. That would be handy for troubleshooting.
Work for Victron (feature request)
As @lxonline mentioned, 47v at 50% SOC is a real alarm signal. Please make different measurements on battery, cables, connections etc.
All of my installations are fited with 16s battery and even at 12% SOC + 50A discharging current keep the voltage at 51.7v.
The displayed voltage comes from the Multiplus II.
Which BMSs are used in the battery?
Can’t you read the voltage from these in the Cerbo?
In the first voltage picture you can also see the voltage from the battery (yixiang).
The BMS is JKBMS.
After charging the battery to 100% the voltages are in line with expectations again. The whole soc range from 10 to 90% shows around 53V now!
So again, it just was a massive SOC drift case.
Thanks all for your comments and suggestions that pointed me in the correct direction.
And yes, if Victron staff reads this, please update the alarm message contents to be more informative. I see the console shows ‘low battery voltage’, but the email message just shows ‘low battery’. Also adding the measured value to message (also in the console) would be helpfull as well!
Cheers,
-Marcel
90% at 53Volt is to low
Can you read the JKBMS voltage or better connect the JK with the Cerbo.
I use dbus-serialbattery and can read every cell
