Hello Everyone,
Nice to be here. I haven’t been on forums since the 2010s, it’s a nice feeling and from what i have read so far, a nice community too.
I would like to introduce you a situation which I encounter since my PV system was installed (more than 1 month ago).
First, my system main components:
- one MultiPlus-II 48/10000/140-100 inverter;
- 3x LiFePo4 Battery 51,2 V/100Ah NG;
- 3 SmartSolar MPPT 250/100 -TR Ve Can
- 26x Canadian Solar 460 W
My connection to the Grid is ensured through a 150 m long underground cable (10mm2 AL) ( I mentioned this part because i think it is relevant).
The situation is the following, when the system consumes from the Public Grid, I have really high spikes of A (for example, when I extract 400-500 W from the Grid, the V is 220-230 stable, but the current goes nuts, sometimes hitting 30-40 A (or even higher). Even in the situations when the system was at rest (the panels are not producing, the battery is not charging/discharging) the minimum current from the grid as like 2 A for everything under 150 W. So if i had a consumption of 50 W from the grid, i would still have minimum 2 A (which is huge for this power, when V is constant 210-230).
From what I have been able to observe (through multiple trial and errors with changes in the system parameters) I have managed to narrow the presence of this problem to the following situation:
- it appears that the spikes are present when the battery charges from the Grid.
At this moment, i switched the system physically to the “Grid” (which i thought that it meant that my home will draw energy directly from the public grid, but it is not the case) from “Victron system”. This way i thought that i will bypass Victron configuration (i wanted to see if that this is the problem), but the electricity still passes through the inverter. However, this was not entirely in vain because now the house is entirely charging from the public network at a stable rate (V stable and A stable) WHILE battery is discharging. This is an important part because from what i have been able to see is that when the battery starts to charge (even a few W, most probably to “balance” the cells, individually) the A goes nuts, if my home consumes 800-1000 W and a few W goes to the battery, the entire consumption is plagued with 20-30 A for 1000 W drawns from the grid (again, with V stable at 210-230).
This being said, i don’t know if i identified correctly the problem (i still investigate this with my installer) but i tend to think that i found the situation when these spikes appear. Now, i don’t know why and more important, i don’t know what i could do. Any opinions, suggestions would be well received.
PS: I don’t know why my post was moved in “DIY”. I started it in the “Q&A and Troubleshooting” section.
