I have checked that using the same system ,same settings, everything the same.
i installed v3.79 on cerbo-gx and my get 14.4kw from grid, if i update to 3.80 or later the power grid is limited to 10kw. i use 3 multiplus II 5000 in parallel. i don´t have meter, I use clamp in the master unit.
Please could victron support department review what happened in the newer version?
Thanks in advance
