Solarsense 750 loses/resets daily yield
Hello everyone,
with the Solarsense 750 running the current firmware, I’ve noticed that it often loses the daily yield, or resets.
You can also clearly see in VRM how the daily yield jumps back during the day.
Has anyone got any ideas?
You sure something can’t shade it? It has a very small sensor so is easily shaded by anything.
Have not seen issues on mine that aren’t explained by the placement of the sensor.
Hi Nick,
It’s not about the power display (see image 2), but about the cumulative daily yield (see image 1).
It shouldn’t jump to zero during the day; at most, it should continue as a horizontal line.
Indeed. That doesn’t seem right. I wonder if it could be resetting due to bluetooth disconnecting?
I did not use that widget (I use custom ones) but checked on mine and it behaves correctly.
I’ll look up some more data for you later
It’s the same with Victron Connect.
That does help with context. Is this a new device?
If that is what VC is reporting then VRM wouldn’t be different.
I noticed when I first installed that bluetooth was quite weak (I proxy via a shelly gateway), but if local stats are the same then that’s not it.
Hi @DirkW and @nickdb, this sounds like an issue we’ve been chasing for a while now, and we’re almost ready to release a firmware update to the VictronConnect beta channel.
Similar reports here and here.
Hi @Luc
This looks like the error in the post on the right.
Have it on HQ2606
Do you need any more data, or have you got the error?
And how do I get access to the beta channel?
Hi @DirkW, we don’t need further data but thank you :slight_smile:
It depends on which platform you’re running VC on. Instructions can be found here.
That explains it, I am on the beta. Didn’t realise it :grimacing:
I’ve installed the VC beta.
Is there a beta firmware for the Solarsense that fixes the error, or is that still to come?
My Solarsense is connected to the GX device via Shelly…
The beta firmware hasn’t been released yet.
HI @Luc
Thanks for the info.
I thought it was my fault that I couldn’t find the beta firmware.
