Hi community.
I have problem with missing solar yield.
I running beta 3.80 but it has been missing for 2 months.
Anyone there has a solution?
Please update to the production release of 3.80 and see if it makes a difference.
Hi Nick.
I roll back to the software and it is still the same.
Is the device visible on the gx?
Can you connect to it via the victron connect app over Bluetooth?
(Assuming a victron mppt that is)
Hi Nick.
Its a ac coupled solaredge inverter, no communication.
I have put a shelly to measure production and it have been solid for the last year or so.
I have noticed the UTC is 2 hours behind, and i have adjusted the clock, but later the same day it is 2 hours behind again.
I set it to my normal time ( Copenhagen) and also UTC but same result later same day. ( UTC time is 2 hours behind again).
Ok, so its a modification of sorts.
You need to start by checking the Shelly is visible and working.
These (device dependent) are supported natively now with new code - have a read of the Shelly integration docs.
Once you can see the meter correctly and set its role the rest should follow.
Some shelly devices and the older integrations can be temperamental.
Hi
UTC is Coordinated Universal Time, which everything is based on. So the time in Copenhagen is UTC+2 in summer and UTC+1 in winter… just as it should be
I find the problem.
When i revert the Shelly measurement in the Shelly settings it work. ( See pictures. )
I know the Shelly is config right in the first place because i use the same device in Home Assistant and now it is not working correct over there.
Please some in the Victron stab, fix this problem.
