For those struggling like I was to understand why solar panels make voltage but no current.
The advice on the Internet wasn’t it.
If you at my image, the problem was too fold both at the same time.
My Hall Effect ammeter did not show current, as the wires were faulty
And
The resesetable fuse breaker is cheap, the volts got through but not allowing current, so the MPPT did not send any current.
The other problem in testing, I hooked up the multimeter plugs wrong.
I show normal mode and the moder for a 10A testing.
Hopes this helps someone.
People are right, solar panels, even second hand ones do not fail
I have both 2 yr old ones and second hand really old ones.
My problem was a lack of simple knowledge on setting up a multimeter to test
solar panel current
And a cheap resettable fuse, that let me down.
What a waste of time I had taking down 11 solar panels only to discover something else was wrong. Hope this helps someone. Rob
