Solar inverters missing in venusOS
Somehow my Growatt PV inverters have gone missing after the grid connection was upgraded from a single phase to 3-phase connection. Both missing in VRM and in VenusOS. I’m actually a bit puzzled about this since two of the AC connected inverters are still on L1. Still charging the battery, and the production is still visible on a self made NodeRED dashboard.
Currently still only one Multiplus II on L1 (bidirectionally connected on AC-in) and the battery is charging, but not using all PV power.
I have one additional PV inverter moved over to L2, but everything is put on L1 by a script (reads data from the kWh meters). Worked flawlessly for over a year and a half so what am I missing here?
I have a VM-3P75CT setup as grid meter, but still only with one single CT clamp. I will change this later today so that all three are installed, but I am still missing some hardware to make this work. Will arrive this afternoon. Hence the lack of solar production in VRM etc
Edit: I wonder if the phase rotation (L1-L3-L2) could be the culprit. It might just be the lack of CT clamps on all phases but the Victron grid meter is still set to 1 phase only. Yeah puzzled. Something new to me.
Edit-2: It magically started to show up again. A day after I added the CT clamps. I surely did not solve this issue myself.
Did nothing on the software side of things, other than switching the meter setting from L1 only to 3-phase.
