I have a new van I specifically bought to run ac…induction and microwave all at once in the Western Australian heat Sept to Dec.
Its a 48v 180ah (4 x 12.8v lifepo) with 1300w on the roof 3 x small panels on mppt 100/20 and 4 x 250w on mppt 150/45.
I have full sun 19 deg days to 30 deg days and the only time I have seen the solar live reading go beyond 686w total was when cloud edge spike happened, it stayed at 1096w for 7 secs as long as it took the sun to move from the cloud, the other timebwas when the system did a rebalance and the cvl went from 54v to 56.8v, I then got 800w readings, clearly theres 2 issues.
My caravan maker thinks its a bad bypass diode, but why would I get the extra solar when the rebalance happened? I think a setting is throttling the solar plus the bypass diode is the issue.
I have spent weeks trying to sort this out and the van maker said he cant do anything, all settings look fine. He said he’ll look at it in Nov when I bring the van back from my travels.
I can’t run anything even the hotplate without it discharging the battery.
Im furious as the whole reason I bought this was to run everything in the heat.
yes aircon. Even without anything running off this it isnt getting the full solar. I would like to run the ac on the hot 30+days. The ac cycles down to 790w. My hotplate I use now and then for cooking for 4 to 10 mins max and that pulls 800w so the solar doesnt even cover that, nor the ac running on its own.
it seems to be throttling the solar as it doesnt matter what outside temp is from 19 deg to 34 deg it doesnt get much higher that 686w…except as I mentioned 3 days ago with rebalance and a cloud spike of 1093w a week ago. Please see screen shots which show the rebalance where I got 800w on both mppts.
Yes the smaller 3 panels seem to be doing well. The bigger ones not so.
Thanks for your info.
I tried the calculator but it kept going around in a loop?
The puzzling thing is why would the mppts reach 1093w with the cloud edge effect for about 7 seconds and also reach 800w all day when the system did a rebalance? Its like theres a setting that restricts the solar all other times?
I’d try setting the charging voltage on the MPPT a bit higher. What are the cable resistances between the MPPT and the battery terminals, or, more specifically, what are the voltage drops while charging? Voltage drops are easier to measure: +MPPT against +battery, and the same for the negative side.
Looking at the cerbo gx watching the mppts the voltage on the large panels sit at 79v to 83v mostly in midday full sun then it will randomly drop to 59v and go back up to 80v. The smaller panels are consistent at around 64v. Is this what you mean? My knowledge is limited with all this.
Watch this video (I hope you can understand Swiss German) and multiply the voltages by 4 (max. 58.4 V). That might increase the charging current.
I hope you have SmartSolar MPPTs; if so, you can do that with VictronConnect over Bluetooth.
If the voltage at the panels fluctuates, the MPPT is looking for an optimal operating point, or it’s throttling for some reason (perhaps the output voltage is too close to the set charging voltage). You always need to look at the input (solar) and output (battery) currents as well.
Thanks for the video. My mppt is set to 56.8v absorption in the victronconnect app and 54v float.
I did a battery balance yesterday as one of the batterys had 3.30 to 3.33v.
Since doing the balance and getting the van maker to make the CVL 56.8v not 54V I am seeing higher solar input. I got 883w highest reading from 1300w today which is an improvement but it still means the 4 x 250w panels are only giving me 575w -50% of solar as opposed to the 3 smaller that got 308w reading today. So maybe a bad bypass diode is the problem?
The van maker changed the Soc threshold in the victronconnect app from 80% to 90% is this how the CVL is changed on the dvcc?
I dont know what exact models they are the van maker couldn’t remember when I asked him the details. I’ll get him to email them to me.
I’ll upload a photo of my setup. Ignore the dust and shadows as this was taken at 4pm. The panels have had rain and the live data was taken at midday when there is no shadows and the aerial is turned side ways.
If there is no shading at all and the solar panels are producing less power, the cause may be short-circuited bypass diodes.
Diode short circuit: The diode conducts continuously, permanently short-circuiting one third of the panel. This can be identified by a hotter area of the panel (about 20–50 K hotter) and reduced panel output (about 33%). So, with a sufficiently sensitive thermal camera, you can find the affected area of the panel because one third of its surface is hotter.
As the panel voltage drops close to the battery voltage, the output can also fall more sharply. With two parallel strings, the output can drop by half if one string has a significantly lower voltage. The MPPT may settle on the lower-power operating point because the combination of the two strings produces two maxima.
If you don’t have a thermal camera, you can also check the voltage of each individual string, but even two panels connected in series can already produce a dangerously high voltage. With a short-circuited diode and two panels in series, the voltage is about 17% lower than that of an intact string.
Yes. I think thats the problem. I was hoping it was all caused by software settings.
I got the van maker to remotely log in and change the Cvl to 56.8v too instead of 54v which gives me more battery usage and fully charges the battery. The way he had it set was it would charge to 54v then stop and rest at 53.13v. 80% soc? It was causing inbalanced cells too. I also changed the repeat absorption from his 30 days to 7 given I have 4 x 12.8v in series (as per victron manual says).
I cant get on the roof out bush to check anything so I’ll wait until I can get the van back to the manufacturer in Nov to fix it.
