I recognized that the cycle reading in my smartshunt is very low.
Cumulated discharge of my battery is 6012Ah and the battery capacity is set to 330Ah. So I expect something like 6012/330=18 cycles. But the smartshunt says just 7 cycles. Why?
The detail is in the manual from memory. Again ftom memory without checking, for a cycle the SOC must fall below a threshold which may be something like 65% and get charged back full. My old boat batteries were 4 years old when I changed them, but as they normally cycled between 80% and 100% they only claimed 50 or so cycles.
Thanks for explanation. So the smartshunt calculates cycles very different than battery BMS usually do. Yes, most of the times I do not discharge my battery below 65%. So smartshunt cycles are meaningless for me as they miss micro cycling.
