SmartShunt connection to busbar
Where in the system should I connect a SmartShunt if I have two LiFePO4 batteries connected in parallel using busbars?
I’d like to use the following setup. Is this correct?
Run a cable from the positive terminal of each battery to a busbar, and do the same from each negative terminal to a separate busbar.
Run a cable from the negative busbar to the ‘battery minus’ side of the shunt. Connect the ‘system minus’ side of the shunt to all the negative connections of the chargers (MultiPlus and DC-DC charger) and the loads.
Run the red wire from the positive busbar to the Vbatt+ terminal on the SmartShunt, and run fused cables from the positive busbar to the positive connections of the chargers and loads.
That is correct.
Okay, thanks
I wasn’t entirely sure, because I’d read somewhere in a blog that the SmartShunt had to be positioned between the busbar and the battery’s negative terminal. It just didn’t say how :frowning:
Normally, the negative busbar refers to the busbar that all the loads and chargers connect to, you are adding a second busbar for the battery negatives.
Yes, I think I understand you. There’s a busbar for the battery negatives >> cable to the battery-negative shunt >> system negative >> cable to a busbar to which the loads and chargers are connected.
Thanks again for the explanation
