Damn cat. Not yet installed. Suggested test?
Pre RMA instructions can be found at the link below, this could be used.
It depends what equipment you have as a DIY. I have a good digital multi meter (DMM) with DC clampmeter so I would connect to a battery check it connects via BlueTooth, check voltage is displayed OK vs DMM then draw a load and check again via DMM.
Thank you
