I need a device that disconnects a battery at a 9V cut-off threshold and reconnects it at 11V. The Smart BatteryProtect manual lists several preconfigured thresholds that can be programmed via the pin; the lowest is 9.5V. I would like to know whether it is possible to set lower thresholds via the app. Thank you.
The VictronConnect app has a demo mode, when opened click the 3 bars and go to demo mode and work through.the menu structure to your product, then you can explore the settings options.
i believe you have the option to choose user defined.
