Hi
I would like to use a battery protect to turn on a external relay when the battery protect voltage reaches 12 volt and turn off the relay when voltage reaches 13 volt.
This is operation is the reverse of what the battery protect is designed for ( turn off when voltage 12 volt and turn on when voltage 13 volts. )
Is there a way to do this by just using the battery protect without external relay.
E.g maybe use mode A Buzzer / led setting.
Thank You
Graham O
I can use the external relay to get what I what be inverting the N/O / N/C contacts
