Small modification on the Community Guidelines to reflect actual layout...
In the Guidelines
One picture can be updated…
From this:
1
To this, or similar:
2
Agreed. This was a direct copy from the old forum. Will fix. Thanks for the report.
Guidelines updated.
Thanks!
The second paragraph below the picture
Even if you didn’t ask the original question, if you see or are helped by an answer on the site, you can also click to accept it as well. This will elevate the answer and help others who have the same issue.
don’t hold true anymore. Only the OP can click on the Solution, which is a good thing in my opinion.
Bar the situation when admins do that, but it shouldn’t be necessary as I’ve saw that the system reminds you, from time to time, to select a solution.
True.
Then maybe a helpful button needs to be added. Sort of like the like button but more related to when it helped a different person?
We’re a bit limited in what can be added. The like button is probably the best option.
