Small BMS NG on Cerbo GX with firmware V3.80
I tried to connect the Small BMS NG via the new Bluetooth integration on a Cerbo GX with firmware V3.80.
When I do I get a lot of random continuous alarms. If I connect to the BMS with Victron Connect from my iPhone the BMS is working fine and there are no errors.
I have tried this on two separate Cerbo GX units.
Has anyone else been successful with this connection.
Could you please make some screenshots of the errors?
Below are from my VRM with the Small BMS NG connected.
The follow images are from my iPhone while the alarms were sounding in VRM
Let me know if you need anything else.
So, I have solved my issue. Looks like I had a single digit in the Encryption key typed in incorrectly. As I was copying and pasting this each time I was repeating the error in each Cerbo.
Once I set up an additional BMS and Cerbo to tests with I realized my mistake.
At least now I know what to look for if I enter an incorrect key again. :blush:
