Skylla Firmware Update via MK3-USB Interface
Hi everyone,
Quick question:
Can I use a MK3-USB interface to locally update/upload the firmware of a Victron Skylla IP65 12/70 Ve.Can charger?
If not, what is the correct method to update the firmware on a Skylla IP65 locally?
I’m having a problem. The firmware got corrupted because communication was interrupted while I was updating it via a Cerbo GX and VRM.
Thanks in advance.
The MK3 is VE.Bus not VE.Can.
You need a VE.Can to USB interface but that is very expensive.
Thank you Matthias!..Yes…I saw the price…It is really expensive. Greetings from Argentina. Have a great day!
