Silence Fan assistant does not work as expected in ESS mode
Hello everyone.
I have Multiplus 24/1600/40 with ESS assistant enabled. I need battery priority during the day and charging during the night. Everything works fine.
I wanted to disable a fan while charging at night, so I installed the Silence Fan Assistant.
Configured to disable fan during the charging.
Now, the fan is disabled during the night charging. Perfect.
The current drops from 40A to 16A, but it’s enough for me.
But during the day when the grid is connected, the inverter power in ESS mode is throttled to ~300W, and the fan is still disabled, but I expected the fan to be enabled and the inverter will work at full power. I need full power from the inverter.
When I manually disconnect the grid the fan becomes active and works as it should. The inverter provides full power.
On another Multiplus without ESS assistant, everything works well.
Looks like a bug in Silence Fan Assistant for me.
Any thoughts? Maybe I did something wrong.
