Shelly Pro EM-50 -> Switching from Wi-Fi to LAN -> Opportunity Loads
Hi everyone, I’m absolutely thrilled with the Shelly integration and the Opportunity Loads.
I use a Cerbo with Venus OS 3.81 + Shelly Pro EM-50
I have the following challenges:
  • I had to switch my Shelly from Wi-Fi to LAN.
    The Cerbo didn’t seem to like that very much.
    After that, it wouldn’t add the Shelly again with the changed IP and MAC address.
    After another scan, it seemed to be detected, but it was still showing the old Wi-Fi IP address.
    Unfortunately, the Shelly’s VRM instance changed as a result too.
    A few attempts to fix this caused the GUI to crash.
  • I’m not 100% sure, but I could have sworn that my heat pump, which is connected to CT1 and was configured accordingly, showed up as an Opportunity Load (before I switched from Wi-Fi to LAN).
    Can anyone confirm whether that’s how it’s supposed to work, or did I just imagine it!?
    Channel A on the Shelly was also set as a heat pump in Venus OS.
    But of course, it can’t be controlled and only shows consumption, so I’m a bit unsure now.
  • I’ve also noticed that the name for channel B on the Shelly doesn’t seem to be read, whereas it works for channel A if I change the name in the Shelly.
  • Somehow, the Cerbo still seems to have merged the old and new VRM instances, because the energy total shown under “Devices” matches the original cumulative value.
  • It looks different in the VRM Portal, where I started from zero.
  • Oh yes, I also experimented with the device names.
    I used both Heat pump and HeatPump for channel A.
    Now channel A is called Heat pump in the Shelly web interface and under Devices on the Cerbo, but under Settings/Integrations/Shelly it still says HeatPump.
    A bit confusing for me…
General tip: don’t use diacritics in names and devices that could be considered technical. It often works, but just as often it doesn’t.
I haven’t either, but if you mean the quotation marks, I’ve removed them :wink:
I was able to answer one question myself:
The devices only appear under Opportunity Loads if they offer the -Function- option under Settings/Devices, where you then have to select Opportunity Loads.
Nice detective work figuring out the Function option requirement! Those little settings are easy to miss. Hope the LAN switch settles down now.
I meant Waëpu, but I think it’s working now anyway?
