Shelly pro 2PM
Volgende maand installeren ze een Victron MultiPlus-II 48/5000/70-50-GX en batterij ,
ik zou daarop mijn boiler willen sturen met een shelly pro 2PM , geschakeld als 2 polig functie
Kan de cerbo GX dit model ook aanvaarden en sturen
veel dank
Yes, I’m using them as well.
They have some Issues with MDNS Discovery after a while, but when added with a static IP that is no problem. (At least I noted that for my hardware rev 1 devices)
Depending on the power of your heating rods, you may better use 2 single channel devices. Due to their compact housing, the 2PMs cannot run at full load for long. They’ll overheat quite fast and turn off to avoid taking damage.
Thanks,
It’s a 2 kW resistor, so 8.7 A,
