I noted yesterday after a week being on the wrong time that the Victron system time had not changed following the British clocks going back to GMT. When set up I thought that the time zone was set up for our clock system. I have been into settings and changed it to GMT, as that is what we are on now. I am not confident that this is the correct setting to ensure the the biannual transition between GMT and BST.
You have to set your time zone.
The changeover happens automatically.
BST is GMT+1, after all.
Thank you for your response. I am confused as to why you have referred me to the link that you have. Is the time not set in the Cerbo setting menu, general, date time? In there I have settled on Europe GMT. When I went in to change the time I think it was set at an UTC value. I did not do the initial set up it was done remotely for me by my supplier. I just need confirmation or other, that what I have set will deal with BST when the time comes. I only realised the clock had not changed when my scheduled charge started an hour earlier than it was programmed to do. The set up was commissioned in May so the time was correct from then until our clocks reverted to GMT.
I found that the CERBO did not change the time automatically when wintertime started, i had to reboot the thing.
Thanks for sharing your experience. When I changed the setting to GMT it flagged up to reboot.
