Finished installing the Multiplus II 3024 and need a password to configure with the Mk3 to finish it off. Dealer won’t be open til Monday am… any help appreciated.
Not supposed post the password per rules of this site and I want to respect that. You may find the programming password here if you read long enough.
Simply ask the most known search engine in AI mode. I guess we have to change the old rtfm to something like ask ai first. scnr
Technically it’s a victron connect password, not the mk3.
Veconfigure can be used with no passwords, apart from trying to change grid codes once originally set.
Yes , it is a victron connect password , that I need sometimes when connecting to my old MP I with the Victron Connect Software.
RTFM? I have not heard that before. Does that mean “Read, The, Fairly easy to find, Manual”?
Thanks. Occam’s razor situation. Seems the answer was that simple.
Thank you, I had run into it but figured it was blanked - like the ### version - but nope! that was actually it. Thank you for your help.
