Hi Folks!
I’m amazed that I am not able to set the equalization voltage in my Multi 2x120.
As such, the equalization feature that’s exposed in the Cerbo settings is useless.
To me, it’s as if the Multiplus does not support equalization at all. How can it if you can’t set the voltage?
The second request is also important. In the Cerbo settings for Remote Genset it would be ideal to be able to configure the relays for adjustable activation. Ie, close the relay for 10 seconds on both startup and shutdown.
Both of these are, to me, no-brainers. The fact that the multiplus does not support setting an equalization voltage really surprises me.
This should be very easy to add to the existing code but it would complete some overlooked areas. Thank you!
