Run HWC dependent on battery SOC, and with remote switching through Cerbo
System: 2x 5KVA MultiPlus II in parallel, BYD LVS 24kWh batteries, Cerbo, SmartSolar MPPTs.
I want to switch on the hot water cylinder circuit dependent on battery state of charge, e.g. HWC on at 95%, HWC off at 90%. I also want the circuit to be switchable through VRM relay switches.
Two questions:
  1. Can I use the K1 relay on the master inverter to drive a 12VDC contactor, which in turn drives a 230Vac contactor to turn the cylinder on and off?
  2. Can I run the 12VDC + from the K1 through the Cerbo NC relay and then to the 12VDC on the contactor so the circuit is switchable remotely?
If there is a better way to do it, please let me know!
TIA
Ross.
Have considered to switch the load via Shelly and use NodeRed to control the Shelly?
NodeRed is more easy to deploy and debug compared to some Victron assistants.
I personally have all my automation in Home Assistant integrated with the Cerbo via HACS MQTT integration.
I’ll look into that, thanks for the suggestion.
Using AC Out 2 and switching it using an Relay Assistant using SoC running the inverters is another alternative. You can get clever and hook an Aux input on the inverter to Relay 2 on the Cerbo, and then use Node-RED to control it.
But as @BjoernK suggested, doing the control logic somewhere else (Shelly + Node-RED on the Cerbo) can be easier.
Also, I believe the Shelly switching is soon to become much easier if you don’t want to play with Node-RED.
I prefer using Shelly‘s for non-critical control and high frequent switching, as it is easier to replace if the relais is damaged.
For critical, rare switching e.g. emergency disconnect I go for MP2 or Cerbo internal relais.
For those uses cases I do not want to rely on network working properly.
