With the GX, the display apparently stays “in the housing” rather than being on the lid like on the regular Multis … that was my first thought too … hence the deleted post further up
That would make sense too. But are you sure the display isn’t mounted to the housing, or perhaps used to be? The one in the video is a GX too, just like the OP’s.
On the standard Multi Plus 2, 302 is the connection to the diode board on the front cover. But this connector is keyed and can’t be plugged in the wrong way round. Strangely, you can’t see a connection at this point in the video either …
But in the last 10 seconds, you can see that the ribbon cable just needs to be attached to the cover as well … done …
Brilliant … sometimes it really is the little things
Just putting this out there … if anyone else is still following along … the J 302 connector, which is free on the “main board”, as we saw, should also be able to power a diode board from a standard MultiPlus 2 on the GX … which of course isn’t connected … but what if … would that give you a separate indication of the Grid and Charger status?
