Resistive Tank Inputs display
I’m using two of the inputs for fresh and gray water, but two phantom “fuel” tanks appear in the display also. Is there a way to hide those, so only the water tanks display?
In the v2 gui. Settings → Integrations → Tank and Temperature Sensors.
Disable the ones not being used. An option to remove will then show in the device list.
In the v1 gui It’s Settings, I/O, Analog inputs.
Got it. Thank you!
