Request: Limit ESS charge power Multiplus when DVCC is enabled
Hello
My configuration is like this:
1 MP
1 RS solar charger
1 AC coupled solar system
2 15kWh batteries.
I ran my system for a couple of months now and all seems to be working fine.
I enabled DESS and DVCC so my BMS is in charge.
My MP is a bit noisy so I made some nodered flows to limit the charge and inverter power during certain time of the day by setting this parameter
I noticed that the ESS max charge power parameter is not respeced when DVCC is enabled.
I raised this point to victron and they say please use the DVCC limit charge current option
But this limits the charge current of my Multiplus and my RS solar charge.
I don’t want to limit the charging of my RS solar charger. I just want to limit the MP.
The ESS max charge power limits the MP only.
Could we get the ESS Limit charge power also working when DVCC is enabled?
Topic moved to modifications. Please note, only the Modifications and Beta sections have currently transitioned. As this involves nodered and a feature request this is the best place currently.
