Remove GX relay from widget
I am trying to remove the GX internal relay switch from the widget as per screenshot, for no other reason other than I don’t use it and want to tidy up the screen!
The manual suggests I should be able to toggle this via the remote console integration settings, but no option for GX relays is shown
Is this maybe because it’s a Multiplus ii GX device, or am I missing something obvious!
VRM firmware is 3.80-51beta
Just to add - VS is switched off in VE configure
Scroll to the end of the device list, there should be the Menu GX Relays:
There you can set “Show Controls” to “Off”.
Not sure if that affects the widgets, but worth a try.
Thanks Dognose
That was what I was anticipating, but they don’t seem to appear on my device list (in VRM or remote console) as attached. Maybe because it’s a Multiplus GX and not a full Cerbo.
