I need a redundant inverter product for US Grid, vacation home. It will be unoccupied much of the time so it needs to be able to handle a single failure with no issue. Need about 24kva total output. I would like three inverters for maximum N+1 redundancy.
Availability of products is limited for the US market.
You can parallel systems for power (ones that support it) but it is not for redundancy - if one fails the system goes down until manually reconfigured, and wired accordingly.
The inverter RS systems, the off-grid variant, can tolerate a loss of a unit but aren’t available in 110V nor support being on-grid.
The topology you are looking for does not really exist. Not yet, anyway.
