I’ve got two Multiplus II and want to use the included temperature sense connection ( 8. Appendix ) to measure e.g. room-temperature, but not (as intended) the battery-temperature.
After connecting the temperature sense to the first Multiplus, you can access this temperature at DBUS com.victronenergy.vebus.YOURCONNECTION/Dc/0/Temperature => that’s fine.
Communication to my battery-system is done via BMS.
Do I have to apply any special configuration so that the temperature of the external sense is not taking into consideration for adapting the battery-charging?
After connecting the second temperature sense to the second Multiplus, I see no change at all.
Is there a way to access both connected temperature sense respectivey if no, how does multiple Multipluses deal with multiple sensors?
I know how to measure temperature via raspberry pi (e.g. DS18b20), and I think it would be no great effort to achieve this also on Venus OS.
But I wanted to add temperature measurement with miminum effort. This is the case with temperature sense via primary Multiplus, that’s fine for me.
