@JeffT What size mm2 cable do you have between the batteries and inverter? Also, click on the cog to show range values in reports which may flag up something. What is the reporting logging interval set at? For fault finding set to 1 min. The ripple definitely has to be looked into and one factor is undersized cabling.
