Pylontech US5000 "High voltage alarm" at end of charge on hot sunny days: cell imbalance?
Hi all,
My Pylontech batteries throw an occasional “High voltage alarm” on the Battery Monitor [512], and I’d like to understand whether it’s cell imbalance and how best to deal with it.
System
MultiPlus-II 48/5000/70-50 (VE.Bus 568), ESS, Cerbo GX on Venus OS v3.85
2× Pylontech US5000 on CAN-bus (200 Ah), SOH 93 %
AC-coupled PV: 4 Hoymiles microinverters on AC-in
DVCC on, “Limit managed battery charge voltage” = 51.5 V (the battery requests 53.2 V)
Symptom
The alarm comes now and then, always around midday on hot, sunny days, when the battery reaches the top of charge. It clears by itself a few minutes later.
On most days when the battery fills up, the SOC jumps by 4–5 % in under 5 minutes (e.g. 91 → 96 %) while the pack is only at about 51.2 V and charging at 2–3.5 kW.
At mid SOC the cell spread is only 3–5 mV.
Questions
Does this look like cell imbalance showing only at high SOC?
Would you keep the limit at 51.5 V, or raise it (e.g. 52.0 V) so the BMS has more time to balance?
Would it help to limit the charge power above ~90 % SOC, so the end of charge is slower?
Thanks!
Hi again. There are numerous topics on this subject already. Please start by searching for those topics and continuing the discussion there unless there is something unique to your issue. Everything you are trying to find, almost certainly, has answers already on existing discussions.
Don’t panic about warnings, they are just that and are normal on unbalanced systems. Leave it to sort itself out without fiddling with it, leave it on keep charged, for an extended period. Monitor what happens, it will either resolve or you will have data to show what cells and voltages are being reached, then you can make a call.
51.5V is too low. Let the GX algorithm for the pylontechs work their magic. There is a bug on 3.85 that does not honour the CCL, either use the beta or rollback to 3.79.
SOC sticking below 100% and hopping up, is also normal.
view the BMS min/cell voltage widget
