PV production ends when battery full
I have Easysolar II, grid connected, 8kwh battery and 4,86 kw PVs. Normally produces well and sells to grid in trade mode. However when battery is full production shuts down, instead of selling to grid. This leads to loss of production/sales.
Any idea what causes the production stop and what can be done to rectify?
there are known issues around this on a MultiRS. It is a combination of venus os version, dess instructions and firmware-version.
It could probably affect the Easysolar II as well. This is being worked on to be resolved in 3.80 and new Firmware-Versions for the MultiRS. (I will add to the devs that the Easysolar is looked at as well)
Depending on your versions, it sometimes helps to disable DESS, when the battery is full. If that helps, you could temporary use a node-red script to disable dynamic ess on 99 or 100% soc, and enable again short before sell-time usually starts
Is DC feed-in activated in the ESS settings of the GX device?
