PV power only increases when a large consumer is switched on
Why does my PV power only increase when a large consumer is switched on? Why doesn’t it charge my battery at this high rate?
Did I set something wrong?
You would need to share your base programming and settings for us to know.
Are you grid connected or off grid?
If battery is fully charged for instance then system is working correctly.
But without all system settings being known, this is but one assumption
