Local grid utilisation project
Works very well with Victron systems:
Upload data via script and take part.
You can find the scripts and integrations under GitHub > GitHub > data-collection-ortsnetz-auslastung
Interesting idea, but it won’t tell us all that much. After all, you only measure at your own grid connection, which is linked via an unknown grid topology to an unknown local distribution transformer. You don’t know how many other users share a line with you or what its cross-section is. Then there’s the question of what else is happening on the line at the time. If the grid operator did this with the many smart meters (in Germany = hahahaha), it would make a lot more sense, because at least in theory they should know the cable cross-sections and so on.
Yes. I completely agree with you. Nevertheless, the project is interesting.
So, here the houses are connected with 70 mm² cables and protected by 200 or 250 A fuses. Our transformer is 500 kVA, if I remember correctly!
Cheers
