Hello everyone.
I’m new to this forum and have the following problem. I have a Mercedes Viano W639 with a brand-new battery. To charge my EcoFlow Delta Pro, with an EcoFlow Smart Battery connected to it (both 3600W), while driving, my husband bought a Victron 12|800. Unfortunately, he’s no longer here to help me. I’ve installed it as follows.
The Victron’s negative terminal is connected to the same ground as the car battery.
The power supply (red cable) runs from the positive terminal to the Victron, with a 125A fuse in between.
Both cables are 25mm².
The Victron switches on successfully. If I connect a device to it, it works.
To protect the alternator, I’ve limited the AC input to 500W.
I only want to switch on the Victron while driving, so I don’t drain the car battery. I do this manually.
The EcoFlow is also charged by 240W of solar panels on the roof, when the sun is strong enough, of course. This works without any problems.
I start the car and switch on the Victron.
Now for the problem: it makes no difference whether I’m driving or stationary. The EcoFlow doesn’t charge and just makes a ticking sound. It has worked twice (randomly; I couldn’t figure out if I did anything differently), but most of the time it doesn’t.
At home, the EcoFlows are connected via a PowerStream to a total of 900W of solar panels, and this works without any problems. Charging via mains power is no problem either.
What could be causing the EcoFlow not to charge from the car battery?
Thanks in advance for your help!
Best wishes,
Marion
