Prevent grid feed -in with RS Smart Solar RS48 6000 inverter
On the camping place it is absolutely not allowed to feed in to the grid. I would like to purchase a RS 48 6000 with battery and solar panels to get more than the 16Amps i can draw from the grid. But is it possible to set grid feed-in to zero? I could not find it in the instalation manual.
Rob K
Maybe you are considering the wrong product. Only the Multi RS has a grid connection, and yes you can prevent feed in.
Search for “Feed-in allowed”
The feed in is automatically not allowed when you pick the right grid code.
I created a virtuel switch in Nodered to disable feed-in:
Screenshot 4
This will then show up on the Cerbo GX:
Thanks, this looks very promissing. I will have to study this Node-Red stuff and see I i am able to create this for myself. I found a lot of info about it on the internet.
Rob K
