I have a 12/2000 Smart inverter and I’m trying to connect to Victron App without success. The Pin code on the label does not work and the Puk code is not present in the label. How can I obtain the PUK code? I can send you the product label.
https://www.victronenergy.com/support
You can put an official request in on the page linked. It is often recoverable through a distributor.
The other way to change settings is with a redirect to usb (or ve direct to BT) or though the vrm if you have a GX.
Thanks!! I will try
