Would anyone point me in the direction of a manual for a Phoenix Multi Plus “VE Bus inside” inverter/charger.
Don’t find one in the “old manuals” section …
Might be too old.
What exact model do you have?
What are you looking for?
2x Phoenix Multi Plus 24/3000/70 connected in parallel.
Haven’t removed the covers yet but will tomorrow … will likely answer some questions
Would like to find a drawing of the connections/manual
Ultimately would like to know if a GX device is connectable
Yes, taking off the cover would be good.
Actually the MultiPlus 3000 hasn’t changed much over the last 15-20 years.
You might have to do a FW update, but with that old device you will only have limited functionality.
Limited functionality would likely be perfect
Remote access and a shore disconnect warning would be super
Hopefully removing the cover shows 19xx111 processor … fingers crossed
Can it be interrogated with a VE.Bus USB dongle?
Processor is labelled 1911115.HEX so I guess should be OK
