Peak Shaving is limiting my power output via AC-IN
I just lowered my contracted power with the company and set the maximum import amperage in Peak Shaving in Venus OS.
After setting the amperage to the minimum, 5A, the network began to go out from time to time and after investigating I discovered that my inverter has stopped investing more than 5A.
The loads that are not being supplied by Peak-Shaving are placed on the AC-In and are detected by the Carlo Gavazzi.
I’m going to leave remote support enabled. I’ve currently raised the limit to 40A for Peak Shaving to work but I need to try to keep it low to charge from the grid at a maximum of 1kW.
