Peak Shaving 5% hysteresis
Hi all,
Is there a way to change the 5% hysteresis in the Peak Shaving mode?
explanation :
When you have a large battery ( 100 kwh ) you have a lot of rest power for the winter.
BUT when we change the SOC to 70% ( for example ) , peak Shaving mode will go to 65% and then recharge battery and load from Grid,
when you have big battery you want to have more “peak shaving space” , so lets say 15% ( or custum adjustable )
When we have 3 days of no sun … we can go deaper in soc than the 5% histeresis
Is there a way to disable gird change battery after Peak shaving fail , or a number for that also , like for example 10% extra charge than.
OR is there a registery modbus address for this also? so we can change that via Home Assistant ?
Grid charging is money , solar is free :slight_smile:
