Can I bring all the PE conductors (AC in1+2, AC out 1+2) together at one point and connect them to the unit with a single cable?
The Quattro has a central earthing screw for connecting a PE conductor to a central PE distribution busbar.
What exactly does your electrical installation look like? If you connect the incoming and outgoing cables incorrectly, you will no longer have a reliable PE connection (loose connection, increased leakage resistance), which can lead to life-threatening subsequent faults.
I would neatly terminate the individual PE conductors on an earth bar, then connect it to the Quattro.
The PE is all common in the unit.
Test it out.
And read the manual; if anything is unclear, ask here on the forum!
