Parallel 3x 6K5 scaling error Cerbo GUI
We have 3 × MultiPlus-II 6k5 units in parallel on a single-phase grid. It’s a new installation, and we’re loading on AC-Out1 with roughly 8 kW. The fans on all three units are running, all at the same level, so the load sharing seems fine. What we notice on the Cerbo is that the “load indicator” is only shown based on the capacity of one inverter (going into orange color).
The “inverter” LEDs on the units are blinking/toggling in sync. Does anyone have an idea what this could be? The Cerbo was updated today to the latest firmware (v3.85 Large). The MultiPlus units were updated yesterday to v560, and all of them are visible (with the master as “zero”).
After the initial configuration (3 in parallel on L1), we used VEConfigure 3 to configure all three inverters (“send to all units”). We verified this on each inverter. After that, ESS was installed on all three inverters (written to one unit at a time, separately for each). So I don’t expect a problem there…
Does anyone have an idea? Could the scaling be off?
