Orion XS reverse charging with dual Orion XS units: feature request automatic disable
The new feature is AWESOME! I have two features I am hoping are in the works. So first question may just be is there a outlook for updates tot he feature that are planned?
One I am looking out for is a trickle charge style setting. I have a feeling that one may be in the works though.
The other I am wondering if others have the need because I imagine it may not be as high priority and possibly has other solutions to make it work. That would be a sort of automatic disable of the second Orion in a system during a reverse charge from one of them. In my mobile system I have a 50A and a 70A running from a high output alternator, so if I don’t disable the unit that is not reverse charging it just creates a big loop feeding back to itself. Currently I just disable on the remote console or connect app, and I know I could wire a switch into the remote on/off terminals to do the same. I will likely do the latter for now, but it would be most straight forward if somehow through the VE network it knew to turn off redundant dc-dc chargers during a reverse charge. It is possible I am also missing a fully automated way to do that that exists already. Thanks!
I have two Orion XS-50.
Sometimes, I am able to start the emergency charging feature on both units, sometimes not.
In this case, when I am trying to start the 2nd unit, it’s too late. The 2nd unit already started to charge back the lithium/house battery, creating a loop.
I am using “Automatic engine shutdown detection” instead of the Remote input to trigger charging the lithium/house battery. I might have to change the voltages settings to trigger the automatic detection or, wire the remote input.
Running v3.90-beta9
