Orion XS 50Amp 12V DC/DC Charger
I recently installed a Orion on my catamaran and my alternator has the capacity of 55 amps. With the lithium house bank at 87% state of charge, I’m only getting 250 watts (20 amps) flowing into house bank as measured by the Cerbo display. The output starts around 200 watts at 2000 RPM and goes up to 250 watts at 3000 rpm. Would would expect more current output from the Orion. Any thoughts?
At 87% state of charge your lithium bank is almost certainly already in absorption, where the charge current tapers down on its own — the Orion is likely just following the battery’s acceptance rather than limiting anything. The fact that output rises with RPM tells me the input side is doing its job fine. If you want to confirm the full 50 A capability, try it with the house bank discharged to around 50% and watch the Cerbo input voltage at the same time: if it sags noticeably under load, there may be cable or connection losses between the alternator and the Orion.
To my understanding, when the Victron Orion XS starts drawing current from an input source (such as an alternator), it ramps up its input current.
There is then active monitoring / throttling that regulates the current so that the source does not drop to its shutdown / lockout voltages.
Your alternator capacity is relatively low and close to the maximum capacity of the Orion XS. That could be the issue? Perhaps try allowing your second battery to discharge so you know you’ll go straight into bulk and ensuring your charge source battery is fully charged and monitor the current then.
A 55 Amp alternator typically has a 55A capability when cold and this will reduce when hot. The alternator is probably also supplying current to the start battery and other circuits on the start battery so has less charge available for the house battery.
there is also the possibility that you are boosting say 13.8V to 14.4V which will need 21A input for 20A output. If your wiring is too small then the voltage drop can add to the voltage difference between input and output.
The typical guidance is the DC to DC charger should be rated for around 50% of the alternator capacity, 65% at the very most.
