I have a case with an off-grid Victron system, MP-II 3000, Cerbo GX, SmartShunt 500, 3xMPPT’s and 24V AGM batteries.
Now, the requirement is to add a DC-DC charger for a single 12V AGM battery to be charged from the 24V “main” system and I am looking to Orion XS 1400, this will be connected/managed by GX device through VE.Direct-USB.
- The charger usage schematic of this Orion involves it’s own SmartShunt, on the output, is that mandatory ?
- Due to GX connection, is it possible to prioritize 24v battery and only charge the 12v battery from surplus solar ?
- As only thin wiring is available for remote 12v battery, input current will be set to 5A
SmartShunt. This is not mandatory, it is used if you need to monitor the 12V battery SOC.
Solar charging. Set the engine shutdown detection voltage to something higher than the 24V battery resting voltage when full, say 26.4V. Then it will only charge when the 24V battery is charging.
Current limit. This will be OK as long as the wires are suitably fused and the Orion settings can go that low. Try the demo mode in VictronConnect to see the settings range.
if you connect the Orion to the GX device the GX device assumes it charges the 24V battery, there will be a setting in the device to tell the GX device that the Orion is a load on the 24V battery.
Thank you for valuable information.
SOC monitoring is not that important, but is Orion at least able to show voltage and current of the 12v battery ? That would give a glimpse of battery status, actual consumer is really small and single.
If I add a SmartShunt, is that able to pair with Orion through bluetooth or need a separate VE.Direct ? Being a remote 12v battery, I would prefer only one data cable, that is already in place.
Excellent tip !
I am a bit confused on this point, is that a setting in the GX - Devices - Orion area or directly on the Orion ? If I set the Orion as a load for GX device, will Orion still be capable of charging or will become just a power supply ?
12V battery monitoring - The Orion will monitor the 12V battery voltage and current flowing to the battery. I do not know if you can Bluetooth connect the Orion to a SmartShunt, in theory you should be able to. The Orion details will be on Node-RED if you use this so you could create a virtual battery with the voltage from the Orion so it was on your available battery monitors.
Orion load setting. This is a setting on the GX under the Orion device settings. If you do not tell it the Orion is a load, it will assume it is charging the 24V bank rather than using energy from that bank and affect some of the system consumption figures. If you use DVCC on your 24V bank it will try and apply this to the Orion which will cause problems. Setting it as a load means it still works as a charger, it is to tell the GX that it uses energy from the 24V rather than supplying it with energy.
Thank you for all this info !
