Orion-Tr Smart not charging with smart alternator and solar active – Fiat Ducato Euro 6
Hi everyone,
I’m experiencing an issue with my Victron Orion-Tr Smart DC-DC charger in my Fiat Ducato camper with a smart alternator.
My setup:
  • Fiat Ducato Euro 6 with smart alternator
  • Victron Orion-Tr Smart 12/12-30A
  • Victron Lithium Battery Smart 160Ah (single battery)
  • Victron MultiPlus 12/1600/70-16
  • Cerbo GX with DVCC enabled
  • VE.Bus BMS
  • 2 × 200W Renogy solar panels with Victron MPPT controllers
  • Orion connected to the vehicle’s D+ signal via the remote connector
The problem:
When driving, the Orion often remains in Float mode (13.5V) instead of actively charging the leisure battery, even when the battery is not fully charged (for example, 93% SOC).
At the same time, the solar MPPT controllers are producing power and maintaining the battery voltage around 13.4–13.5V.
My suspicion is that the solar charging keeps the battery voltage high enough to prevent the Orion from restarting a Bulk charging cycle.
The smart alternator can also reduce its output voltage significantly (I’ve observed around 11.7V at the Orion input). I understand this can happen with smart alternators, although I haven’t yet confirmed whether the voltage is the same directly at the starter battery.
Current Orion settings:
  • Absorption: 14.2V
  • Float: 13.5V
  • Re-Bulk voltage offset: 0.1V
  • Fixed absorption: 2 hours
  • Engine shutdown detection: Enabled
  • Alternator type: Smart alternator
  • Start voltage: 14.0V
  • Delayed start voltage: 13.3V
  • Shutdown voltage: 13.1V
My questions:
  1. Is this a known behaviour when an Orion-Tr Smart operates alongside solar MPPT chargers?
  2. Is there a recommended setting to make the Orion start charging when the engine is running, even if solar is maintaining a relatively high battery voltage?
  3. With a D+ connection, should engine shutdown detection remain enabled, or is there a better configuration for a Fiat Ducato smart alternator?
  4. Would upgrading to the newer Orion XS 50A improve this situation, particularly with its VE.Direct connection and DVCC integration with the Cerbo GX?
Ideally, I’d like the Orion to contribute to charging whenever the engine is running and the leisure battery needs charging, without interfering with the solar system or risking discharge of the starter battery.
Any advice or experience with a similar Fiat Ducato setup would be greatly appreciated.
Thanks in advance!
